Sunfire TrueSub EQ
Username: Frankz2018
Here's my problem;
Nothing but a loud hum when I turn it on.
Nothing else. I've tried it with my inputs (RCA) connected and without, no difference.
I've checked all four fuses with my DVM and all are good.
No obvious burnt components, caps do not appear discolored or deformed.
Any suggestions would be greatly appreciated.
Username: Jan_b_vigne
Dallas, TX
Post Number: 18529
Ground issue. Could be bad power supply caps or a broken solder joint.
Solder joints looked good, even under 10x magnification. No cracks, lifted components or obvious corrosion.
Dallas, TX
Post Number: 18530
If you've ruled out one possibility, you move to the next.
Need to Register?
Forgot Password?
Enable HTML code in message
