Panasonic av control stereo receiver sa ht275
Username: Goldie666
Just bought a Panasonic av control stereo receiver sa ht275 at goodwill. Having trouble hooking up my speakers to it. Downloaded manual. It said it comes with its own 5 speakers. Can I not hook up my own speakers to it? Just want audio for my record player and CD player. Have done so many hook up combinations and nothing works. Help?! Thanks!
Username: Magfan
Post Number: 3610
MOST 8 ohm speakers should be just fine.
The receiver will have trouble with speakers rated at 4 ohms.....
Start with a SIMPLE pair. Hook them to Left and Right....You will have a Black and a Red connector for each speaker.....
Find a instruction manual online for the receiver. Find out how to reset the configuration then set it up for stereo to start.
Add speakers as you learn how it operates.
Need to Register?
Forgot Password?
Enable HTML code in message
