I was looking on Amazon.com and I have been buying 8" to replace my cabinet ones that have blown. (Finally) So I was wondering if I could hook up my 2 8" subs to my receiver and use a mini power stereo power amplifier with it? I have a Onkyo Home Theater receiver and 2 8" Lanzar Max8 600 watt subwoofers.
Basically, I want to hook up my 2 8" Lanzar subs to the mini stereo amplifer and possibly hook up the mini amp to my reciever.. is this possible?
Well Warner, most HT receivers made since the mid 90s have sub/LFE outputs. If your receiver is a 7.2 channel, run one RCA cable from each sub out to a channel of the power amp and the power amp out to the subs. If it's a 5.1 or 7.1 channel receiver, you'll need to plug a Y splitter into your receiver's sub/LFE out and plug your cables into the Y splitter in order to use both subwoofers.
