Re: NAD C352 one channel weak at very low volume
Username: Acupoftea
Took me some years to post a follow-up on my question from March 6, 2006.
I finally solved the problem with Goldenjacks -10dB attenuators,
placed between pre-out and main-in. With them, I can listen at low
volume to /both/ channels ;). And the remote volume control becomes usable.
Thanks
Username: Nuck
Post Number: 15698
Geez, for the last 5 years I have had the feeling that I was forgetting something. Thanks!
Need to Register?
Forgot Password?
Enable HTML code in message
