Nad T762 Subwoofer Setting
In the OSD of the Speaker settings of the T762 there is a Subwoofer setting where I can vary the Mhz's. What do I set this to? I have a PSB Sub 6. Also I ran a subwoofer cable from the sub out on the T762 and used a Y-cable to the Low Level Input From Pre Amp R & L plug ins on the Sub 6. Is this correct?
AdamT
The Hz setting for the sub determines the crossover point for signals sent to the sub and other speakers. Which setting you choose depends upon the base response of your other speakers. If they have pretty decent base response you probably want to use 80 Hz as the cutoff. On the other hand, if you're using small satellites with limited base response you'll want to use something higher--like 120 or 150 Hz.
I'm using PSB 6T's as my mains.
