LP skipping
Username: Eli19k
I just purchased a Pro-Ject Debut III and while listening to an a LP (a 180 Gram reissue) and the Debut III is skipping at times that this record didnt on my old turntable a budget model sony usb turntable. I adjusted my counterweight and some of the skipping is gone but not all of it. this is my only LP to do this while playing. is this normal when going to a higher quality system that im guessing has much lower tolerances?
Username: Eli19k
After posting I got my old turntable hooked up and my LP is not skipping at all on it, i have also tried my best to clean it
Username: Jan_b_vigne
Dallas, TX
Post Number: 14712
Make certain you've properly adjusted the arm and the anti-skating; http://www.audiophilia.com/features/cartridge_setup.htm
Which cartridge are you using? Is the bottom of the cartridge rubbing on the LP surface due to any warps in the disc? Set the arm down in the lead in groove and slowly rotate the platter by hand to check for sufficient clearance between the disc and the cartridge bottom.
Username: Eli19k
i readjusted the arm and the problem went away, this is my first time using a turntable i had to set up myself. thanks for the advice
Need to Register?
Forgot Password?
Enable HTML code in message
