Marantz PMD-430
Username: Striker308
Lancaster, PA USA
I just recently purchased this used and was told it might need new belts. What are the symptoms of needing belt replacement or new motor?
Username: Redturbo917
Burbank, California
I am wondering the same about my marantz 430. I can get the play, fast forward and rewind work with manual encouragement. It wiorks off and on. My unit is clean but had been in storage. any ideas out there?
mike
Username: Jan_b_vigne
Dallas, TX
Post Number: 13873
Then it needs to be taken down and serviced by someone familiar with the deck. Grease hardens, old junk that had accumulated on the flywheel and idler drive turns into teflon. This is not a job you can take on.
Burbank, California
Thanks Jan!
I had not thought of the old grease. I live in Los Angeles so i am sure I can get it serviced. Thanks so much for your help. :-)
Mike
Need to Register?
Forgot Password?
Enable HTML code in message
