NAD T512 DVD player
SteveB
Hello all,
I'm crossposting this question here because of so many NAD fans visit. Original post here https://www.ecoustics.com/electronics/forum/home-video/6114.html
I have a NAD T512 DVD player and I've changed the prom on it so as to enable SVCD playback. I wrote the orginal code down before I changed anything, but as luck has it, I now can't find my note book (paper not computer) that I wrote the code in. Could someone with a North American version of the NAD T512 check the code on their player and post it.
To check the code,
Turn your Player on
Pause
1472
write the code down, power off.
Thanks
Steve
Gal
Steve, I wish I could help you out but I don't have this player I am woundering though how did you find this out? Do you think I can I get my Toshiba DVD player to do this as well (re-program it)?
Thanks for any help
SteveB
Gal,
I came upon this when I was researching the purchase of the NAD T512. If I recall there is alot of tweaks to be found of different DVD players listed on www.dvdrhelp.com. Check there and see if your model is listed.
Steve
Gal
Wow thanks Steve
I'll check it out - this should be cool
