Connecting a Stereo Receiver/Integrated Amp/Equalizer
Username: Stevekirk
North little rock, AR United States
I have a Marantz 2265 Stereo receiver and reciently purchased a Integrated amp and EQ. How do I connect a Pioneer 6500II integrated amp and a pioneer 9500 Equalizer to the receiver. Then where do I connect my Casste deck, CD player and turntable.
Username: Jan_b_vigne
Dallas, TX
Post Number: 13295
You have an amplifier in the receiver. Why do you want to connect an integrated amplifier to the receiver?
Username: Stevekirk
Is there a way to boost the power using an external amplifier?
Dallas, TX
Post Number: 13302
Not really. Why do you want more power?
Username: Nuck
Post Number: 11441
steve, which componant is to act as preamp for the turntable?
Username: Stevekirk
I guess the marantz!
Username: Nuck
Post Number: 11447
OK. Does the Marantz have a tape loop/monitor on the panel?
Does the Marantz have pre-outs? Might be called main outs. There is a jumper across them.
Username: Stevekirk
there is a main in and a pre out, but no jumper across the two.on the front there is a monitor - source and tape.
Need to Register?
Forgot Password?
Enable HTML code in message
