Do you clean the laser lens in your cdp?
Username: Smwick
B.C Canada
Post Number: 70
I have a Rega Apollo cdp and have used a cleaning CD (the one's with little brushes) to clean the lens a couple of times. The owners manual states "do not attempt to clean the lens, it should not need any servicing." The dealer where I bought it said the cleaning CD would be ok, but I don't know. What do you guy's think? I did a search but couldn't find any posts.
Username: Frank_abela
Berkshire UK
Post Number: 3337
Question is - why do you think it needs cleaning? Unless it's in a smokey atmosphere it shouldn't need cleaning and what ain't broke don't need fixing. That said, if it is in a smokey atmosphere, then occasional cleaning may be beneficial.
the thing to bear in mind is that cleaning is always an abrasive process to a greater or lesser degree. You have a lens there. Any brushing is a low amount of scrubbing, any liquid cleaner is designed to help that process to remove any grunge. unfortunately it can attack the coating on the lens. the liquid will be a very mild detergent but it will have its effect over time.
Me personally? I wouldn't do it. but if you're in a smokey atmosphere, perhaps it's worth doing once every 3 months or so.
Username: Artk
Albany, Oregon USA
Post Number: 8143
Is that about similar to the answer I gave to your PM Steve...
Username: Smwick
B.C Canada
Post Number: 81
Frank, thank you. No smokey environment here so I won't be cleaning it again.
Art, yes it is. I had posted this question a little while ago but got no reply so I thought I would PM you about it. Thanks for you reply.
Username: Artk
Albany, Oregon USA
Post Number: 8146
Enjoy your Apollo Steve.
