New member Username: JbrealtyPost Number: 8 Registered: May-08 | I am thinking of an amp upgrade ... any advise on which of these would sound the most transparent, precise and musical? (I may upgrade my speakers down the road but like the 9.1s for now) Any other similarly priced suggestions that might be better than what Im considering. Thanks Rotel 1062 Cambridge 640a v2 NAD c355bee or c272/162 or c372 Current Specs: Two Channel Audio/Video System Video: Panasonic TH-50PX60U 50" Plasma Denon DVD 1930CI DVD Player Audio: NAD C720BEE Stereo Amplifier Cambridge Audio 640c V2 Wharfedale Diamond 9.1 Monitors REL T1 Subwoofer Blue Jeans LC-1 Stereo Audio Cables Canare 4S11 Speaker Cable, Bi-wired Sanus 26" Steel Monitor Stands |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 1045 Registered: Feb-07 | The NAD would be the lowest on my list. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 7088 Registered: Feb-05 | Add the Rega amps and Creek Evo to that. |
New member Username: JbrealtyPost Number: 9 Registered: May-08 | hmmm creek evo sounds interesting ... think that would sound better than my other options? noticable difference in my current set up that would be worth the upgrade? have enough power for future speaker upgrades? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12736 Registered: May-04 | . Try one of the class T amps such as the Trends. http://www.enjoythemusic.com/magazine/equipment/0707/trends_audio_ta101.htm Unless you want to blast your music, this should work with your present speakers. When you upgrade speakers, don't buy speakers that suck power. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 7089 Registered: Feb-05 | The Creek Evo would likely be a good match...well balanced and lively. |
New member Username: JbrealtyPost Number: 10 Registered: May-08 | What about a Creek Classic 5050SE? I noticed the older models got great reviews, any reviews on this current model? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 7099 Registered: Feb-05 | Those are very nice amps as well. Some folks find them a bit too lively however I doubt that would be a problem with the Wharfedales. |
Bronze Member Username: ArturgorniakAllentown, PA US Post Number: 29 Registered: May-08 | I am using Creek Classic 5350SE with Arcam FMJ CD36 and Spendors S5e and I have to tell you that I love it. As you can see in my other posts I was about to give up on Creek for his ear ripping sound untill it got approx. 200 hours where he started to show up what is capable of!!!!!!!! Sweet, warm, smooth sound with jaw dropping soundstage. I have no clue how it might sound with Wharfedales but DO NOT buy that amp without auditioning burned-in unit!!!!!! Here is the deal: you will either love it or hate it!!!!!!!! (nothing in between) I have to say that 5350SE Is one of the best bargain on the integrated amps' market BUT only when matched with the right equipment!!!! Safer choice would be with Evo.......... |
Silver Member Username: HawkbillyNova Scotia Canada Post Number: 365 Registered: Jul-07 | "have enough power for future speaker upgrades?" Speaker upgrades shouldn't assume more power requirements. Often, it's quite the contrary. More power doesn't equal better sound. Some of the best sounding amps I've heard are under 25 watts, matched with reasonably efficient speakers. Of course, it all depends on taste and listening habits. Everyone's is different. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 3068 Registered: Sep-04 | The brand new Arcam FMJ A28 impressed me enormously recently. I ahven't tried the cheaper A18 yet, but I'd have to put it on your short list. If it's anything like it's bigger brother, it'll be quite something. |
