Buying amps
Username: Nvmyboom
Post Number: 314
where is the best place to buy good priced and good quality home amplifiers, im looking for an amp to power a TC Sounds 12" DVC Subwoofer 2 Ohm sub?
Username: Wattsssup
Barrie, ON Canada
Post Number: 238
local dealer.
Username: Nvmyboom
Post Number: 315
where on the net?/ so i can compare prices
Username: Lamcam
Stanton, Ca Usa
Post Number: 64
local dealers
Username: Frank_abela
Berkshire UK
Post Number: 2877
This sounds like a car audio question. I suggest you'd probably be better off asking in the Car Audio section...
Username: Flyingleaf
Well personally I will find some hot local deals. And I recommend you to have a look in music123.com I have got to know a 10% off couopon from them, maybe that can be useful to you:
http://www.dealstudio.com/searchdeals.php?deal_id=96492&ru=282
