Benjamin Garnoff | hi, i am looking to set up a stereo in my room, and i have no idea where to start. i have a small room, so i was thinking along the lines of a two speaker system with a sub-woofer. so, if anyone could tell me what all i need to purchase, that'd be great. i am on a sub $500 budget. thanks a lot. |
New member Username: EdisonPost Number: 23 Registered: 12-2003 | You can get this Denon - mission exec system for 60% off here. It is one of the best sounding all in one package at a great savings (refurb) http://www.ecost.com/ecost/shop/detail.asp?DPNo=269436&adcampaign=email,ECOSTBIZ RATE You have $250 left for a sub - you can get a good one for that. Axiom has a good one. http://www.vertigoonline.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AES &Category_Code=A4 or You can get all separate one with bigger speakers, and no sub. CD player - Denon 370 is a good one at a 75% off: http://www.ecost.com/ecost/shop/detail.asp?dpno=103497 Panasonic Sa-xr25 is a good new digital receiver (surround sound ready) http://www.etronics.com/product.asp?stk_code=pansaxr25&svbname=16 And finally axiom speakers http://www.vertigoonline.com/Merchant2/merchant.mvc? For $500, you will have a better sounding system than the above Denon system. It will sound better than $1500 system bought at a typical electronic shops offering yamaha, sony, jvc, etc. |
New member Username: HawkPost Number: 28 Registered: 12-2003 | Benjamin: I have shopped this category for my daughter and I have found a few gems worth considering. First, I am very high on the Onkyo CS-210 mini-system, which, unlike the Denon/Mission system mentioned above, has bi-polar transistor outputs rather than IC outputs. Bi-polars are much smoother and realistic sounding, not to mention more powerful, than ICs. Comes with a good CD player built in and a pair of speakers that are surprisingly good. I was quite astounded that it only cost $199 from One Call. See it here: http://ww2.onecall.com/PID_15735.htm Now, add to this a PSB Subzero-i subwoofer for $219 from DMC Electronics and you will have a superb stereo system, perfect for a small room. Just click on this link and scroll down to the Subzero-i: http://www.dmc-electronics.com/Default.htm Good luck! |
New member Username: EdisonPost Number: 42 Registered: 12-2003 | If you decide to go with a Panasonic digital receiver, this upscale model will give you better sound for only $50 more : http://shop.store.yahoo.com/handr-deals/30044.html Another good speaker : Mordaunt Short MS904 http://shop.store.yahoo.com/handr-deals/30044.html |
New member Username: EdisonPost Number: 43 Registered: 12-2003 | Mordaunt Short Speaker sale : http://www.accessories4less.com/Amazing/index.asp?CartId=15430627-EVEREST-BOTSP7 6&FCat=3&FSCat=+++++++9 |
New member Username: EdisonPost Number: 44 Registered: 12-2003 | Benjamin, If you read reviews on the web, and listen to many systems b4 buying, you can get surprisingly good sound for that money these days. There are reviews on this sight, and here: http://www.hifichoice.co.uk http://www.audioreview.com/defaultcrx.aspx If you really want a small system, here is a good sounding computer speaker : http://show.audiogon.com/cgi-bin/shm.pl?spkrfull&1061394800&item&Artech&4&5&6&ht tp://cgi.audiogon.com/cgi-bin/fs_srch.plQQANYAAAApurlsrchAAEXYAAstAAAAAAacoustic _energy You just need to add a cd player like the Denon370, or even a walkman, but the Denon will sound better. |
