Dipole or Bipole witch to go with?
Username: Cory
Post Number: 111
OK, here's the seniro my listening position is located right between the two speakers witch are 5-6 feet away from my ears and would be hang 5-6 feet from the floor.
So what should I go with the Bipole or Dipole speakers?
And if you know why there diffrent can you tell me why?
Thank you for your help!
Username: Kano
Post Number: 332
Bipole is preferable if the sound is being reflected directly behind you - ie you are sitting against or close to a wall. Dipole is preferable if you have more space behind your sitting position.
J. Vigne
http://www.polkaudio.com/home/technology/bidipole.php
