Equalizer hookup
Username: Bills
Athens, OH USA
I have a Harmon Kardon HK 3380 receiver. Can I hookup an equalizer using the Preamp Out/Main In connections to the Line In/Out on the equalizer? Will this affect all of the components - phono - tape -CD?
Username: Monstercable
why should it affect the effect? it will not even if it does it is not a problem
Username: Nuck
Post Number: 7709
Uh huh.
Bill, the tape loop is meant for an eq.
Tape out to the EQ in, reverse the return leads and enable the tape monitor.
Need to Register?
Forgot Password?
Enable HTML code in message
