Any one know where i can download sonic stage 1.5?
install 'kazaalite', or 'overnet' (overnet.com)
goto andr.net if you need more information .
iv lost my sonicsatge disk ...n i want to put new songs onto my minidisk..can sum 1 plezz email tellin me wer i can find it iv tried everywer...
in english plezz!!..email is ledwards666@hotmail.com
hi
http://www.my-minidisc.de/download.html
sonic stage 1.5.0.6
doenutts2005
i have sonic stage 1.5 (a friend done me a copy) but it keeps giving me an error messgae and wont import anything to my music drive and thats befor i have pluged my MD in has anyone got any ideas ?????
Saad
I have lost my sonic stage CD and need to know where I can download it from ? Thank
P.S. In english plz
SnappyIsHere
Try using real player with their plugin for net md....I use it without greif
I've lost my sonicstage disk too!...Please can someone email me with a site to download the original version from please? i have found plenty on sites with the 'upgrade' but this doesn't work alone!... and english site please! thank you, loze25@hotmail.com
I lost my sonic stage disk too. Try the site listed by HI you can dowload the english version 1.5 then go to sony online support and download the update to 2.3
Is there anywhere else apart from the Sony site where i can download sonicstage 2.3?
eric cartman
i have all the files of sonic stage 1.5 on a copied cd but how do i install it? please help saosin1089@aol.com
Connard
I destroy your asssssssssssss sonic stage ! J'te sodomise sale puuuuuuuuuuuuute !!
Connard
Username: Vmax123
Hong Kong
Yes, I can download the sonic stage from HI, but can u tell me where i can download the driver for my Sony network walkman NW-MS70D?
Thank you!
Kaew
http://www.sonydigital-link.com/DNA/common/asp/details.asp?l=en&v=&m=pad
SonicStage Version 3.2 Upgrade Program
http://www.sonydigital-link.com/DNA/SonicStage/SS32.asp?l=en
Canada Guy.
Hey i have a Mini Disk Player Version
NetMD Walkman MZ-ne410 Any1 know what sonic stage i need for this ?? please Post
Every time i trensfer songs to my MD
it gets to 69% or 76% and then my computer
stucks
tried every known program
switched 4 USB cables
is it that my MD-USB port is whacked?
Proton
Yes I have the same problem, any news anyone? I am getting extremley annoyed with this and plan to dump my net MD into the trash and getting an MP3 player, no SONY ones as their software is crap!!! dissapointing really....
Kotaro Kun
I also lost my SS CD too... >.> and.. also i know a way to fix the problem where a song gets stuck around 69% or 76%... IF you are using a english windows recording a non-English song... the problem'll occur... the way i did it is by renaming the song and the song ID using winamp. Try it... IF the problem still remain... just convert the media into .wav using dBpowerAMP. IF still remain unsolved... THEN... I have no idea
Tony in 714
Any experts on SS 1.5 out there? I'm having some problems since I had to do a uninstall and reinstall; now I'm albe to play songs, but not record or import. Need some help
Pls I need SonicStage 2.3.I have vers. 3.3 but not record to minidisc.
Tnks
I have Sonic Stage 2.3 for my Mini Disk. I keep getting a TEMPERARY FOLDER FULL message and I can't put more than three songs in the transfer coolumn. How do I empty this folder?
Hi!
NET MD MZ-410 I need the software- i lost my cd, and the md layer been in my shelf for over a year... and am tired of carrying my cd player.
please help
Hi!
NET MD MZ-410 I need the software- i lost my cd, and the md player been in my shelf for over a year... and am tired of carrying my cd player.
please help
Username: Singnpreacher
Oxford, MS USA
I'm having that problem with my SonicStage Version 4 only getting to 69%, and then staying there for hours and hours without ever transferring anything.
I've successfully made an ATRAC CD with my Lord of the Rings soundtrack CDs. Then another with some top 40 songs. Then another with James Bond themes. They worked, but wouldn't work when I tried putting them together on a disc.
Is there another program that will make an ATRAC CD? I heard that Sony is discontinuing SonicStage and going with something else. Is that true, and will it be soon?
In the mean time, I NEED HELP! Please!
Username: Rellik
Can someone plz link me a download for ver1.5 netmd driver sonicstage or simple burner plz
Username: Juliette_poole
NorwichUk
Hi peeps can anyone help Ive lost me sonic stage disc 3.2 [clever] and now my memory cant be read there for its not allowing me access i think i may need a vesion 3.2 disc to sort me out does anyone know where i can get one from or solve my prob be so greatful!! miss my tunes!!
Username: Alexhh
Try this link:
http://www.sonydigital-link.com/DNA/downloads/downloads.asp?r=forum.ecoustics.co m&f=pad&l=en
then, type the model of your md on the left side of the screen. It worked for me.
Need to Register?
Forgot Password?
Enable HTML code in message
