Looking for 5.1 receiver that is 12" deep
I'm looking for home theater receiver that can fit on a shelf that is only 12" deep. Does anybody know of anything. The closest I have found is a low end Kenwood that is about 13" deep.
Derek
You may have to buy a 5.1 mini-system or executive stereo. The shallowest I can find is 13" also. Although the feet on the bottom would easily fit on a 12" shelf, I assume you don't want it to stick out.
It doesn't matter if the knobs stick out. I do need the feet to sit on the shelf though. What have you found that is close?
Derek
I have a Sherwood that will fit.
