Good decent subwoofer for no more than $200?
AL
I'm currently shopping for a subwoofer. I need advices/suggestions on where to get a good/decent subwoofer for about $200, no more than $250. I'm in Los Angeles, Alhambra area. Any pointers will be greatly appreciated. Thanks in advance.
AL,
Derek
Sony sells a sub. It's part number ends in "40" like sm-40. It is a 10 inch sub that typically costs $150. Sometimes Best Buy has it on sale for $99. Also, look for some of the 8" subs from Energy, Mirrage, Mission. They can be found for around $250.
The Sony's are the SA-WM20 (8") and the SA-WM40 (12") You can get the 40 on eBay for under $100 and the 20 for under $75. The review of the 40 is at http://www.audioreview.com/Subwoofers/Sony,SA-WM40/PRD_124407_2741crx.aspx
and the 20 is
http://www.audioreview.com/Subwoofers/Sony,SA-WM20/PRD_141065_2741crx.aspx
The 40 is an Editor's Pick - really pumps out the bass for the money. I'm trying to decide between the two myself. I'll let you know if I find them cheap!
AL
Thank you Derek and Frank. Please let me know ur pick and where/how much you got it for. Thanks... Really appreciate it.
AL,
Frank Vasquez
Al - My mistake - I have been trying to get the 40 on eBay, and they seem to be hovering around the $139 mark + shipping ($35). You can always go to pricescan.com or pricegrabber.com and do some merchant searches. I have found that Crutchfield.com will ship you the 40 for $160. That's a pretty good deal since eBay seems to be around $170+ with shipping.
Derek
Whoohoo! I just picked up an Energy S8.2-1 for 150 bucks at Brandsmart. Even the sales guys had to take a second look. It was an open box item and I didn't get a manual. I am supprised it's larger than my Athena sub though not as clean sounding. But it works just fine.
