Sad face on my ipod
Username: Burgess
Rochester, NY USA
I can not get my ipod to charge. I get the battery but it does not charge. Then I get a ipod with a sad face. I have tried to reset it but am having ano luck. What do I do now?
Username: Gamerdude
Ontario Canada
Post Number: 89
i read some where about thsi try support on apples site or check ur manual and even call apple and ask some 1 at best buy good luck
Username: Project6
Post Number: 8846
Iris go here
http://docs.info.apple.com/article.html?artnum=61771
Username: Project6
Post Number: 8851
If it still does not work, you need to send it in to be fixed. You probably have a bad hard drive.
Need to Register?
Forgot Password?
Enable HTML code in message
