Connecting 6.1 Speakers to Onkyo TX-SR800
Jasper
Got a quick question that I was hoping someone might know the answer to. I currently have the following 6.1 speaker setup:
Front: 2 Polk RTi38s
Center: Polk CSi30
Surround: 2 Polk FXi30s (set as Bipole)
Back Center: Polk CSi20
Subwoofer: Polk PSW404
I am looking into purchasing the Onkyo Tx-SR800. I was wondering if there is any way to use my current speaker setup, without replacing the CSi20 with two speakers?
Thanks,
Jasper
Phil Krewer
There should be in the menu a way to select using only one surround back speaker and the manual will tell you with connection to make in the back. So yes you can do this.
Phil
