Power cord on Sony turntable
Username: Jdk
Halifax, UK
I have a Sony turntable from a Sony mini system. I have now purchased a seperates system and am wanting to use the turntable with it, but it plugs into the mini system for power via a small cord with 3 pins on the plug. Is there anyway to convert this into a normal mains plug so I can use it without the old mini system?
thank you
Username: Two_cents
Post Number: 720
Check an electronic parts store. There are many cables available that convert one plug type to another.
Username: Jdk
Halifax, UK
