Trichord Dino Phono amp.
Username: Johnnyesox
Glasgow, Strathclyde Scotland
Post Number: 7
Wow,had a loan of one of these Dino,s,plugged into my Rega Planar 3/Eyls/RB300arm,which is wall mounted on the Rega "bracket"...awesome is all I can say.If your in the market for a phono stage,I can thoroughly recommend this little box with the blue light,be prepared to play every one of your albums and be a recluse!
Username: Frank_abela
Berkshire UK
Post Number: 1174
Alternatively if the Michell isn't available locally have a look at Dynavector's P75 or Tom Evans Audio Design MicroGroove both of which are also awesome value.
Me, I use a Tom Evans Groove which is a couple of notches up the scale and just gorgeous - provided you have the record deck/cartridge to go with it.
regards,
Frank.
Post Number: 8
Hi,Frank,managed to secure the Dino and Dino+ power supply at a good price,which I get at the weekend.Borrowed the Dino for a few days and listened to it non stop,then added the Dino+ power supply....even better again!Smoothed everything out.Heard them first of all through my mates Primare amp/Planar 3/Kef Reference 8's.Brill!
