Looking for a replacement phono cable
Username: Oldlou
Franklin, Nc
After 30 years of great service my Dual 701's output cables have started to develop poor connections at the RCA plugs. I have just spent around four hours searching for a new one on the net and have not had any luck. Can anybody point me to a inexpensive source?
Username: Jan_b_vigne
Dallas, TX
Post Number: 7139
You can't find an interconnect cable? You will have to cut off the RCA connectors on one end of any standard interconnect and strip back the insulation. Solder this end to your Dual and you should be all set.
