My daughter bought me the rca lyra 1072 recently and I haven't had any problem with it as far as loading or deleting...my problem is I want to use it to listen to audio books when working. Now I get what I want loaded, it playes fine but not in order...I go from chapter 1 to chapter 5 to chapter 2 to chapter...you get the picture...can anyone help me figure out how to keep it playing in the order I want...
thank you for any help
Alex Summers
The Lyra 1072 has a very simple interface: It only plays tracks in alphabetical order by filename (including any folders). However, you can use this to set the correct order.
After you load the tracks onto the Lyra, open it in Windows Explorer and change the file names so that they will be in the right order (e.g., 01_Chapter 1_First Chapter.mp3, 02_Chapter 2_Second Chapter.mp3, etc.). Now they'll play in the right order.
