Looking For an Ortifon M15E cartridge
Username: Airbornflght
Ok, my dad has been looking for a cartridge to his Pioneer Deck for a while and hasnt been able to find one.
When he bought it, he payed $50 for a M15 cartridge.
I'm trying to find a replacement cartridge for the deck.
Are these cartridges, or a replacement for them, still made? the best that we found is a radioshack piece of junk that has no volume.
I'd really appreciate it for a reply and maybe a few site that are good sources.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7243
To my knowledge the M15 is no longer available. There's no need to replace the cartridge with an identical model; there may be no need to replace a cartridge if the stylus assembly is still available.
http://www.needledoctor.com/
Username: Ca_convert
CardiffUK
Post Number: 175
You can also try these guys out, they are very helpful.
http://www.needles-and-spins.co.uk/
does anyone know what cartridge it takes though, if it takes that cartridge, which one i can buy a a replacement? the cartridge is shot, we tried a new stylus. although, im a bit fuzzy on this elderly technology.
I just need the whole deal, needle, cartridge, whatever they are called, is that just a cartridge? doesnt the cartridge come with the stylus?
CardiffUK
Post Number: 186
A cartridge is the name given to the complete unit which includes the stylus, certainly if you buy one from a dealer then this is what you will get. Moving Magnet cartidges usually have the facility to replace the stylus when worn, a moving coil cartridge usually does not. Why dont you contact a local dealer for advice, this is what the hi fi shops are for. You could probably take your deck to them and they will fit and set it up for you aswell.
we dont have one, our town is a little rinky dink one, about 48,000 people. the closest thing we have is radioshack and we bought a cartidge from them and there is no volume to it now, it sucks, of course it does, its from radioshack.
I emailed ortifon so i will see what they say.
Username: Tweakerttweaker
Try these they should have what you need I think.
http://www.needledoctor.com/s.nl/sc.2/category.378/.f;jsessionid=ac112b1f1f43af2cb395dd2140d0b2ee8167c464f6ca.e3eTaxiNaN0Te38SaxqMaxa Ray1ynknvrkLOlQzNp65In0
http://www.speakerbits.com/Default.aspx?cat=22&menu=12
http://www.adelcom.net/OrtofonStylus1.htm
http://www.musonic.co.uk/erol.html#7431x0&&http%3A%252F%252Fwww.google.com%252Fs earch%3Fq%3DOrtofon+M15E%26hl%3Den%26lr%3D%26start%3D10%26sa%3DN
http://www.turntableneedles.com/index.asp?PageAction=VIEWPROD&ProdID=9339
http://www.export-japan.com/marketing/stylus/product_info.php?cPath=12&products_ id=727&osCsid=86bf2fe3f8a8450e1d14f694b713acbc
http://www.vinylengine.com/phpBB2/index.php
I hope one of these might help you.... Tweaker.
Do you have the turntable plugged into a phono input on the receiver/amplifier. If you do not have a phono pre-amp, that may be the cause of your "no volume" problem.
