Speakers for Nad 3020
Username: Vominhtan74
Can Tho, Can Tho Viet Nam
Dear All,
I have a Nad 3020 too, please give me to choose a secondhand spearker for it
Thanks
Username: Yan
Mojokerto, Jawa-Timur Indonesia
is it NAD 3020 old amp ?
i have NAD 3030, using AR speaker
it's not bad.
Username: Joe_c
Atlanta, GA
Post Number: 999
What brands do you have available?
How much do you want to spend?
Thanks Yan, What model's is?
Hi Joseph coulson : I don't have any attention about Brands; i will spend <500$. Now I play it with B&W 204 (secondhand);
Thanks
Username: Joe_c
Atlanta, GA
Post Number: 1025
Are you able to visit a shop and hear some different speakers?
Username: Yan
i think, with $500 budget, you able to get for new and nowdays speaker type. second hand speaker is ok, but it's depend on how the old pal usage. because i believe the characteristic of internal material will change especially moving parts.
pang
I have NAD c3020 matched with B&W DM602s3 sounded great
Should be try with your 500$
Username: Danman
QUEBEC CANADA
Post Number: 500
B&W, Wharfedale, Epos and PSB come to mind. They like the warm sound of NAD.
Username: Vm8444
Post Number: 11
you should think greatly of my recomendations because i have owned both.. paradigm,,say studio 20 used ,,around 400 or a little more,ones more detailed and full..
http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1129630923
or one of my favs ,,linn kans less then 400,,offer
,,very fast fun and musically exciting,,
http://cls.audiogon.com/cgi-bin/cls.pl?spkrmoni&1131641400
Username: Fps_dean
Williamstown, MA USA
Post Number: 78
Either the Wilson Watt Puppy 7, Infinity Reference Standard Series V (IRS V), or Krell LAT1s or LAT2s will all do just fine :-)
