Need help!!
Username: Zoranporan
Hi. i was wondering if any one would be able to help me out with a slight problem.
I have come a cross a sherwood (model unknown) reciver. And it's not completly working.
The thing is. You can power it on, and you'll see that the reciver is on! (led's light up) but the display isn't working, nor the speakers when you connect them. (tried different) also tried headphones with no luck.
so basicly i was wondering if any one knew what might be wrong with it and how to fix it?
Username: Chitown
Post Number: 421
Even if you fix it, you'll end up with a Sherwood.
There are a lot of really good well priced and refurbished or a/b stock receivers out there. Don't waste your time with this.
