Help in Setting Up / Calibrating my Inifinity Speakers
Username: Aznbimmer
Post Number: 10
Hi, I need a little help in setting up my speakers with the following components:
Receiver: HK AVR 7200
Sub: Infinity Alpha 1200s
Floors: 2 x Infinity Alpha 50s
Center: 1 x Infinity Alpha 37c
Surrounds: 2 x Infinity Alpha 20s
(1) Should I invest in a RABOS Kit to set up the subwoofer?? Or is there an easier way so that I don't have to shell out another $60. (2) The AVR 7200 has a "Triple Crossover System". What is the optimum x-over points for the sub, floors, and surrounds? Any help will greatly be appreciated.
Stray
So how do you like the Alpha set-up?
I think I read that you should set the X-over at the lowest above 70....80 should be good.....Set from Receiver...
Set the 20's to small, center to small and 50's to small and large to see what sounds better to you....
I've heard that the RABOS kit IS a must to give your sub the full potential....It's only $60, definately worth every penny....
Again this is just from the few reviews I have read.....Let me know how the system sounds because I have the 50's, HK630 and was thinking to get the 37c, 1200s and either 20's or 10's
