Vcd recording problem
i have a samsung cd-rw its a computer cd recordable. my question is can i copy vcd through this and also can i use regular cd-r to do so. I have used the nero buring rom 5.5.10 to burn a vcd into the black cd-r, it seem to be burning ok but when i tried to play the recorded cd it did not work. so if someone can see the problem please help me resolve it. thankyou
hello
any help
Username: Project6
Post Number: 649
yes, you should have no problems. You just have to be sure that the player you are using can read cd-r
goto vcdhelp.com
When I record VCD using Picture Package for Sony, it records only for 70MB of space and doesnt record further than that. The CD-R that I used has 700 MB of space. I have a XP with 3GB of free space on C drive.
Can someone tell me what I am (could be) doing wrong.. pls help
Hi,
I am using sony picture package and not able to burn the vcd directly. it dosn't regnosize my cd writer
please help
Thanks in advance
Hi,
please help
Thanks in advance
Need to Register?
Forgot Password?
Enable HTML code in message
