Power Director 3.0 USB Audio MIA
Username: Talosian
Los Angeles, Calif. USA
Post Number: 11
I just got Power Director 3.0 USB and when I capture the picture is GREAT but there is no audio. The "Audio" button is greyed out after the "Capture" screen fully loads. This is a USB and so there is no direct input to my audio card.
I am using a Vidio Capture unit from Turtle Beach since it is the only one which says it will capture Closed Caption, which I need.
I have used Power Director with another USB unit (Xpert Video Maker) and their unit has a separate audio plug which goes right to the sound card and works find but the best picture I get with it is poor quality so I'm stuck with the Turtle Beach unit.
Any help greatly appreciated.
Thanks.
