DIN to RCA wiring question
Bowchar
Okay.
So I am trying to connect my Kenwood Kd-500 to my Philips 900 series receiver. I have found a connection which is a 5-pin female DIN that fits my male DIN connection underneath my tonearm. The problem is, that the female DIN connector has to be wired to two male RCA plugs so that I can connect them to my receiver. And I have no idea how to go about this.
Can anyone help?
J. Vigne
Not sure what you need to know.
Check out the tonearm to preamp cable here:
http://www.hovlandcompany.com/pdf/brochures/Cables.pdf
I have the perfect solution.
Email me for more info.
alfaz@rogers.com
Thanks!
