How often should you change a subwoofer driver
elippe
Hi everyone
One of my buddies has offered to sell me his psb subseries 3i 15 inch subwoofer. He had bought it in 1999. I'm just wondering if the driver will have to be changed soon or if at all? How do you know when to change it?
Thanks
Eric
Username: Touche6784
Post Number: 485
i doubt it unless it looks physically damaged. if anything the surround will probably break down before the woofer does. 6 years is relatively short for home audio stuff. most well made stuff lasts like 20+ years.
elippe
Thanks for the info
Eric
