Belt replacement on sony ps-lx250h please...i know it's been posted
Username: Gratefulgreg
My belt has fallen off and i cannot for the life of me put it back. I read the other posts on this problem but did not understand them. Could someone please post a picture of theirs with the blet on so I can understand it?
Username: Dvautier
Bellevue, Wa Usa
Post Number: 22
I'm not familiar with your unit but try this:
My dual platter has several large inspection holes on it that are under the rubber mat. Most of those belt driven jobs are designed that way. Remove the platter by turning and lifting it up. Remove the rubber mat. Feed the belt around the motor drive capstan. Position the platter just above it's mounting location, and place the belt on the inner track on the underside of the platter, holding the belt in place through the inspection holes with your fingers. Carefully slide the platter onto its spindle. Turn the platter several times to see if the belt is properly tracking. By the way put a few drops of light machine oil on the platter spindle while it is out.
hope it helps.
