Sub wiring? Series, and then Parallel?
Username: Dkstrikesagain
Ok so I'm wondering a way to get 2, 4 ohm voice coils to run at 2 ohms to the amp? Well ok I kinda just wanted to see if this would work, or what? OK so I took one sub and wired it series and then I took another sub and wired it parallel. Then if I take the ends of each set of wires and bridge them at the amp will that give me 2 ohms total like I think it will, or will this just mess up the whole plan? Using the multi-meter I have a 2 ohm load but I'm just not sure if this would work? Somebody help!!!!!
Username: Touche6784
Post Number: 438
ok, so maybe you should read where it is that you are posting. this is the home audio section. pleaes post in the car audio section.
