2 cds in single car cd player
My daughter put (crammed) 2 cds into the single cd player in my Ford Ranger. There is no override eject hole to put a paperclip into, I have tried the eject button and play button but nothing is working. I took off the frame work only to find the face plate seems next to impossible to remove. How do I get the cds out minus the use of dynamite?
shens
plyers?
Username: Edison
Glendale, CA US
Post Number: 828
Don't use the dynamite - take it to a car audio place and have them take it out, or show you how.
Username: Artk
Albany, Oregon USA
Post Number: 1277
Using dynamite may be about as sensible as bringing your car audio problems to the Home Audio Forum.
