NXG and BIC speakers
Username: Cstein1017
I'm considering purchasing either NXG or BIC speakers for a Home Theater. Online editorial reviews of each brand have been consitently solid, recognizing performance per dollar spent. Both seem to be engineered fairly well with materials and functions commonly found in excessively higher priced brands. Any information on either, recommendations on one or the other or neither would be appreciated.
Mc_X_iT
Dont waste your money on these speakers. Neither is a respectable name in terms of hi-fi gear. You would be much better off getting a pair of Paradigms, JBL, which are both a great speaker for the money.
Username: Joe_c
Oakwood, Ga
Post Number: 518
the subs that BIC make are not too bad I have one and like it very much.
Username: T_bomb25
Dayton, Ohio United States
Post Number: 81
The Bic V62 is avery good budget speaker i would buy them before i bought the Athenas.
Thanks to all for your replies. I think I'll pull the trigger on the BIC's. Maybe even buy a JBL or Paradigm center channel speaker and compare.
