Subwoofer
Username: Occam
Post Number: 9
How do I connect a subwoofer if my amp does not have a subwoofer output?
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 763
Firstly what type of amplifier, is it make and model.
Secondly what type of sub bass, do you have make and model.
Username: Chitown
Post Number: 194
Neil you should always be able to go the passive route. Put the sub between the amp and 2 of the receivers.
If you have a good powered active sub, you may consider replacing the amp
Username: Chitown
Post Number: 195
I meant between the amp and 2 of the speakers of course.
Sorry
Username: Occam
Post Number: 10
Do subwoofers have inputs for the two main speakers and then you would run the speakers from the sub? If thats correct then is there a crossover in the sub so your woofer and tweeter only get the higher frequencies?
Username: Kano
Post Number: 541
What kind of subwoofer do you have?
If it's a passive sub which requires speaker wire to be run to an amplifier, you will need an amp capable of driving a hard load, I wouldn't recommend running speakers from the same unit.
If it's a powered sub run the sub from the left/right pre-outs of the amp into the left/right filtered inputs of the sub using 75 ohm coax cable. Make sure you set the crossover on the back of the sub. (80Hz is THX standard)
