Boston speakers sound waivering problem
Username: Country_charm
Hello all... I am having a speaker problem with my Boston speakers, BA735. The sound waivers.. it gets real soft then loud, as if someone were playing with the volume. I've tested this on 2 different computers and the result is the same. Could anyone give me any insight on what the problem might be and if it would be worth having them fixed?
Thanks for any input given.
Username: Chitown
Post Number: 114
Get rid of them. Did you get them with a Gateway? If it's happening on different computers then there is not the sound card or the drivers. They are not that expensive to replace. I have had a BA750G system for almost 5 years now and they are great.
Yes, I did get them with a Gateway. I thought getting rid of them would probably be the best option since they are so small. Thanks a lot for your reply, it's appreciated. Yes, I have other Bostons too and love them.
Thanks again!
