Please help me to choose the budget AMP !!! Urgent
Username: King_henry
JVC RX-6030V / RX-6032V
Key Features:
Dolby Digital, DTS, Dolby Pro Logic II
100 watts x 2 (stereo) into 8 ohms (40-20,000 Hz) at 0.8% THD -- or 100 x 5 in surround mode
JVC AV CompuLink
subwoofer output
5 DAP modes
component video switching (2 in, 1 out, 35MHz bandwidth)
digital inputs: 1 optical, 1 coaxial
3 audio, 2 A/V inputs (including one 5.1-channel)
no phono input
1 set main speaker outputs
fluorescent front-panel display with dimmer
multibrand-for-video remote
30 FM/15 AM presets
17-1/16"W x 5-13/16"H x 17-1/16"D
OR !!
Kenwood -V5070D-S : AV Receiver KRF-V5070D-S
DTS 5.1 ch, Dolby Digital 5.1 ch, Dolby Pro Logic II 5.1 ch decoding
3 Active EQ mode
5 DSP listening modes
Digital AM/FM tuner: 40 presets
Remote control unit (with the capability of controlling Kenwood DVD Players)
2003 new generation stylish flat board design & easy unit operation
Surround power output: 100W x 5 (FTC, 8 ohms, 0.7% THD)
Terminals
3 digital inputs (1 optical, 2 coaxial)
6 audio inputs (including 6 ch input)
2 Audio outputs
3 visual inputs
2 visual outputs
Subwoofer Pre out
6 ch input for DVD Audio reproduction
Amplifier features
24-bit Cystal DSP
24 bit resolution D/A, A/D converters
96kHz/24 bit audio reproduction capability
Midnight mode (Dynamic compression system in Dolby Digital mode)
Independent speaker level control adjustment
2 AC outlets
Loudness control
Bass boost
Full Auto Digital Analogue Input Selector
Set up memory for each channel/Input sensitivity control
(Input level adjust by 3 steps)
Digital REC mode: Auto/Manual
Display dimmer function
Dimensions and weight
W: 440mm x H: 143mm x D: 303mm
9.3kg
Please help me !!! I already confused !!
Give me a susgestion !! I know this is a CHEAP AMP !! please help !!
Username: Tonytiger
PA US
Post Number: 52
I'm not a fan of Kenwood since I never owned one but the Kenwood specs for audio have better digital 'in' capability. I don't use analog for any input on my system. The old question is what do you plan to use it for? % of movies versus listening to music.
Username: Project6
Post Number: 361
the Kenwood has a better power supply than the JVC
Username: Gdawg
Post Number: 88
Henry,
What is your MAXIMUM budget, I would recomend getting a refurb receiver.(ie. Harman 125)
Find the cheapest receiver you can with 6-8 channel pre-outs(Marantz SR4400? Kenwood VR6060?) and upgrade to a power amp later.
You wont find much for power or quality at these levels, but the pre-amp stages are somewhat quality(respectively)in the low end Kenwoods(7060+). This would be a good option as it would leave room for upgrades as your budget increases...
By the way, what speakers are you running?
Remeber your speakers MUST be 8 ohms+ or these receiver will either, turn off and wont turn on again until the speakers are unplugged, or, turn off and blow up completely.
