NAD T773 or NAD T743+NAD
nad or
hi, looking for NAD home cinema electronic. Got these choices:
NAD T773
or NAD T743 couples with NAD T973 amp.
which one should i go? I got full 7.1 NHT speakers
or other better suggestion?
Thanks.......
Username: Artk
Albany, Oregon USA
Post Number: 686
The T773 has a better processor and just sounds better regardless of the amp you put on the T743. Get the T773 and if you want to upgrade put a 2 channel power amp on the T773. Gives you super power on the front 2 and sufficient reserve for the rest.
nad or
thanks. any good suggestion for power amp? NAD? Axiom?
heard Mcintosh is cool, but too pricey.
Username: Ht_addict
I have to agree with Art, the T773 is a phenomenal unit. I have one myself. As far as amps go you may want too look at the NAD S250. Had one of those with my previous setup(56TXi/NAD S250). Depending on your budget checkout www.saturdayaudio.com They seem to have NAD deals all the time.
ht_addict
Username: Artk
Albany, Oregon USA
Post Number: 728
NAD matches its own power amp well. I'm using a Hafler 9505 (250 x 2 into 8 or 375 x 2 into 4) which I picked up used in pristine condition. It REALLY works well with my NAD gear. Almost (almost but not really that close) gives it a tube like quality. Mac is good but very pricey.
