IS KOLE AUDIO A GOOD AMP ANYONE PLEASE REPLY!!!!!!!!
Username: Trini
Port of spainTrinidad
Post Number: 16
specs 2300@1 ohm model Q1 3000d any recommendations
Username: Edison
Glendale, CA US
Post Number: 629
In car amps, I like Nakamichi, and mcintosh.
They are big names in hifi - the Kole is not so known, so I would shy away from them.
If you are bent on getting them, I would go with a class D amp they have.
If you don't want to pay that much for the above 2 ones, look into eclipse amps.
if you don't mind used, get them at ebay and end up with better quailty for the same money.
