Paradigm Studio 40 vs. Paradigm Monitor 5
Username: Mgkaplan
Calabasas, CA USA
Post Number: 8
Has anyone heard these speakers side by side?
Is there much of a difference in sound quality?
Username: Elitefan1
Post Number: 309
Yes and Yes. The 40 is much smoother and images better IMO. For the money the 5 is a very good speaker but if you can afford the 40's go for it.
Username: Robertinchico
Post Number: 7
Paradigm speaker experience: I hastily, without my usual consumer auditioning purchased a pair of Paradigm Titan's as an interim speaker during a system rebuild. Even with fully upgraded cables, I didn't like the sound. I exchanged them for a pair Focus'. With some Straight Wire Sextet CABLES and Rhapsody Interconnects - the Focus are terrifice for $300. Thinking ahead and taking advantage of slow customer traffic, I auditioned the Monitor 5 v3. With upgraded cables, the Monitor 5's (v3) are just excellent for $550ish. So as an option to an initial larger outlay to the Studio 40's, consider trying the Monitor 5's with some upgraded cables/interconnects, and see how good they are. Perhaps a while down the road, with these new cables, you'll find the studio 40's extra money worthwhile. It's a good idea sonically to budget some cable upgrades in to the speaker portion of any speaker or system purchase. Get the most from your speakers with good cables.
