$800-$1000 budget: build me a system.
John Stevens
I was thinking of this:
2x B&W 601s
and a 2nd hand CD player & amp.
eg. Reloop RA-1500 PRO and a ONKYO DX-7333 BLACK (both 2nd hand of course)
Should I get 602s or better speakers insted? And i only listen to heavy metal or metal music, if that helps.
Thank you!
Username: Bezel
I strongly suggest to go with used equipment here.
It's just not possible to get a good system for $1k.
At the same time you can get very good used items in this budget.
Here is an example of the system you can get for this money:
- B&W 602 s2 ($400)
- Rotel RCD-971 ($350)
- Rotel RA-971 ($250)
P.S. I DO NOT suggest exactly this system - it just to help you understand what is the price level you can afford
