Need advice..need receiver for my turntable
Username: Tvega1999
Chelmsford, Ma Us
short question: can someone tell me of a mid-level brand of receiver that will take phono input?
long winded version: I'm not exactly a newbie, I just haven't bought any audio components in YEARS, so I'm out of date. I finally fixed my turntable (my son destroyed the stylus years ago), I got a Sony digital receiver as a gift, but it has no phono input.
I desparately want to play my 45's and lp's, but I don't understand the manufacturer's tech specs found on the web, can't tell whether their audio inputs include phono.
I never had high-end audio components. I just need something of reasonable quality that will play a tape deck, cd player and turntable.
Thanks for your suggestions.
Tom
Username: Konoyaro
San Francisco, CA United States
Post Number: 14
A quick search on the web shows a couple of models that are currently available which include turntable/phono inputs:
Harman/Kardan HK3480 starting at around $270 and the Yamaha RXV1500 starting at just under $600. So there are several choices out there though it'll depend on your budget and other requirements.
Username: Tvega1999
Chelmsford, Ma Us
Thanks so much konoyaro for the suggestions . I looked at both models, and will probably go with the harman kardan.
Thanks again for helping out. I'm one step closer to being able to play my Bob Dylan albums :-)
Username: Konoyaro
Post Number: 15
No problem. Though please note, I just mentioned two random receivers that popped up when doing a google search on "turntable input, receiver". I have no personal experience with either. There are quite a few more items out there that would also fit the bill depending on how much you want to spend, what features you want, etc. In example, the H/K I listed is only 2 channel whereas the Yamaha is 7 channel. There are even phono preamps available for $40 that MAY work with your digital amp. Also, for the price of the H/K, you could probably find a very nice used vintage amp that will have a phono input and sound far better.
Yes, the number of considerations and choices can be mind boggling... Anyway, good luck in your quest.
Username: Frank_abela
Berkshire UK
Post Number: 488
Tom
Most receivers do not have a true phono input and as time goes on, even fewer will do so in future. This has brought about a whole marketplace for external phono 'stages' which act as phono input preamplifiers. These phono stages vary in price from around $75 up to hedonistic levels (mine costs about $3500!) so there is a lot of scope. The really nice thing about external phono stages is that once you're sorted with a phono stage, you can then choose any receiver on the market, rather than restricting you to the odd few that have this particular function.
The cheapest phono stages on the market that I know of are the NAD PP2 and the Pro-ject Phono Box. Both of these are small innocuous boxes (so it's not like you're adding a whole extra component to the system). Just add an interconnect to go between the phono stage and your shiny new Sony receiver and you're off. Certainly, this would be a cheaper alternative than buying a brand new receiver, and oddly you'll probably get better vinyl reproduction because you're using an external phono stage. External stages benefit from not being in amongst the plethora of noise that a typical receiver generates in the box.
Regards,
Frank.
Jeronimo
Onkyo TX-8511 You can find it for less than $300.00
Denon DRA-395 $350.00
Denon DRA-685 $500.00
Good luck
Username: Edster922
Post Number: 319
Frank,
excellent advice, as usual!
Berkshire UK
Post Number: 491
Why thankyou edster...
Username: Tvega1999
Chelmsford, Ma Us
A heart-felt thanks to all of you, for taking a bit of time to educate me.
I will check out the pre-amps you mentioned Frank and konoyaro, and I will also look at the models you mentioned Jeronimo.
My receiver is a Sony str-de345 (it was a gift from my family). I just looked at the real panel, and I looked at the operating instructions, and I don't see where a pre-amp would get connected. I'm sorry, but there's nothing as simple as an 'aux' port, or a port labeled 'pre-amp' (nothing that simple).
What the hell should I be looking for, if I wanted to buy a pre-amp and connect it?
Thanks again.
Tom
Username: Konoyaro
Post Number: 16
Tom, you should be able to use the tape input. This assumes you don't have a cassette deck already hooked up. So the hookup would be turntable>phono stage>tape input. Here's a link to an online vendor who also has a FAQ section:
http://www.kabusa.com/frameset.htm?phonpre.htm
Here's another:
http://www.audioreplay.net/
etc.
The suggestion for a low cost phono stage coupled with your current amp assumes you want the cheapest, shortest route to playing your vinyl. There certainly are many other options out there if you want to upgrade.
Username: Tvega1999
Chelmsford, Ma Us
I hope this doesn't post twice; I also replied to the email from ecoustics;
My message was, thanks again for your help. I'll check the links. I need to hookup a cd, tape deck and turntable. The preamp for the turntable sounded like an option, but as I said, I don't see where it would plug into the Sony I have.
Am I missing it, or do some receivers just do not have that option?
Anyway, I'm very grateful for the information and advice I've received.
Tom
Jeronimo
If you are still interested in a new receiver and if budget permits, check the Rotel RX-1050...it is excellent, should be around $800.00
Just a thought
