6.1 DTS-ES setup problem
I need help. The problem I have is I cant get my receiver to play my DVD in 6.1 ES. Trying to play lord of the rings which is in 6.1, but my receiver sets to matrix dts 6.1 and not true ES 6.1 The dvd player is set right and yes i did select the DTS 6.1 option on the dvd setup, but it is still going matrix. I see on the receiver the 6.1 ES display, but it is not lighting up to show it is in true 6.1 ES, only the stupid matrix. I've checked the manual to see if i missed something in the setup, but i just am not seeing anything wrong. Rear speaker works in matrix, so i know the speaker is functional.
Does anyone have any clue as to what the problem is and what I need to do to get the receiver to decode the 6.1???????????????????????
Username: Jbecvar
Post Number: 49
what receiver and dvd player do you have? And how do you have them hooked up?
Username: Paul_ohstbucks
Post Number: 617
It sounds like it's working right to me. With my receiver, if it doesnt pick up the ES flag automatically, I manually switch it to ES mode.(opposed to my default PL2x setting). Your settings may be correct, but it's missing the flag.
You can fix that manually with your remote.
