Username: Lorand Post Number: 1 Registered: Apr-05
Thursday, April 21, 2005 - 18:52 GMT can you recommend me a good, neutral sounding stereo receiver? I intend to buy Denon DRA455R Have you any experience with this receiver? Thanks for all kind of advice, suggestion
Username: Artk Albany,
Oregon
Post Number: 274 Registered: Feb-05
Friday, April 22, 2005 - 01:48 GMT What's your budget? Marantz SR4320 retails for 429.00 and trumps the Denon hands down. Rotel makes the RX-1052 which is outstanding at 899.00, and NAD has the C720BEE which goes for 599.00. These are the best stereo receivers that I know of at under 1k. Go forth and listen.
Username: Edster922 Abubala,
Ababala
The Occupation
Post Number: 193 Registered: Mar-05
Friday, April 22, 2005 - 06:25 GMT Also look at the H/K 3490, that'd be my first choice probably. About $300 shipped from jandr.com
Username: Touche6784 Post Number: 268 Registered: Nov-04
Friday, April 22, 2005 - 06:26 GMT he meant 3480
Ababala
The Occupation
Post Number: 194 Registered: Mar-05
Friday, April 22, 2005 - 06:31 GMT whoops, right you are Christopher! Time for bed I think. : D
