DVD / CD Player Quality with Digital Out
Username: Garyo
Post Number: 10
If using only the digital audio output of a CD player, do I need to have a good DAC in the CD player or since the Digital to Analog conversion is in the receiver, a less expensive CD player will provide equivalent quality?
Username: Jan_b_vigne
Dallas, TX
Post Number: 4045
The signal that is fed to the DAC will determine the quality of the final product. A better transport mechanism will assure the lowest error readings, aliasing distortion and jitter distortion. It's difficult to find a top notch transport in a lower priced CD player.
Username: Edison
Glendale, CA US
Post Number: 666
Use your computer as a transport - lower jitter makes for an upscale one. There is a lot on this topic here :
http://forum.audiogon.com/cgi-bin/fr.pl?icomp&1&ctg&0&50&
Need to Register?
Forgot Password?
Enable HTML code in message
