Help with amp
Pinner
I have power to my ampflifier, but the amp will not power the subs. My subs are not blown because i unhooked them and put them on the back speakers wire and they worked.
Username: Pimpzeus
United States
Post Number: 7
sounds like u should replace the wires and see if that helps ok. i need ur help pinner. why is it that when i hook mine up it doesnt do anyrthing
