Well, I think I have my heart set on the shelf system I want. I looked at it at wal-mart, and it seems to have two places in the back of it for antennas to plug in...
What kind of antennas do you have to plug in? Is there any place I can find a good, long-range antenna for this type of stereo?
J. Vigne
AM reception is a long piece of wire mounted as high as possible. FM reception is a roof top antenna.
