Like
Help with choices!
I am not a HI FI GUY...I just purchased a Samsung 5063 HD-DLP....I am blown away...I had been watching a 1995 Sony 25" Trinitron from 17-25 feet away...
Now I am hooked on TV!
So...I have to get a surround system.
Here is my question.
Is the Denon 1905 worth getting or should I swallow it and get the 2905?
Again, I am clueless. Thanks!
LongTimeWolf
any help?
Really need an entry level Reciecer with the potiential for growth...
HELP
Probably going to use Paradigm speakers...7 or 5
edster922
If you're mainly doing TV and DVD you really don't need a super duper receiver.
I'd go for the Pioneer 1014 ($400), get a cheap progressive scan DVD like the Toshiba 3960 ($50) and spend most of your budget (60-70%?) on good speakers and a quality subwoofer ($400-600).
Username: Jet2001
Post Number: 16
A lot of guys recommend the Paradigms, you should be happy there.
There are multiple posibilities for an entry level receiver, edster has you on the right track with the Pioneer. I know many people are not, but I am a bit partial to Sony receivers having owned three and will soon be in the market for a fourth. Check out the ES line of Sony and see if it fits your needs...if not there are plenty to choose from like the 1014 that was mentioned.
Facebook
Shop Related Deals
Directory
